はじめに
If your ZTE Quest phone can't hold a charge or you're having trouble turning on your phone, then this guide will provide instructions on how to replace your battery.
必要な工具と部品
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
