メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Follow this guide to remove and replace the battery for the ZTE Maven.
    • Remove the back cover.
  1. If inserted, remove the SIM card and SD card. If inserted, remove the SIM card and SD card.
    • If inserted, remove the SIM card and SD card.
    • Remove midframe screws.
    • Carefully pry between the screen and midframe to release the clips holding it on.
    • Remove the midframe.
    • Carefully, with a pry pick, pry under the battery to cut the adhesive underneath it.
    • If you are having trouble, apply a heated iOpener onto the battery for another minute, then try again.
    • You can also apply a few drops of high concentration isopropyl alcohol to the edges of the battery to help soften the adhesive.
    • Remove the battery.
終わりに
ある他の人がこのガイドを完成しました。
Gigabit87898
メンバー登録日: 2016年04月06日
15,842 ポイント
3のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
296 メンバー
981のガイドは作成済み
8 件のコメント
@gigabit87898 you should consider adding images for each step of any guide. A good guide points out where screws are located, what size they are and if they are all the same etc. It is not enough to write "Remove midframe screws". Remember, guides are written for anybody and keep in mind that people wanting to use your guide to fix their device, may not have your knowledge.
oldturkey03 - 返信
yeah i dont think im going to use a “heat gun” on my battery
Vinny Games - 返信
As long as you do it correctly, it will be fine.
Gigabit87898 -
I have a heat gun, but I think I’ll try a hair dryer first. In the comments under disassembly video at youtube one commenter said the adhesive is just double stick tape. Here’s the video: https://www.youtube.com/watch?v=LY5ltw1X...
Clint Murray - 返信
Why heat the battery?? I need to change the screen in my moms maven and I'm kinda scared tbh. Lol the protective cover freaks me out!! Help me plzzzz?!?
CaRrIe 4TwIn E - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 22
今までの合計 3,238
