はじめに
The screen replacement on a phone becomes essential when the display suffers damage from drops, cracks, or malfunctions such as unresponsive touch or dead pixels. A damaged screen not only affects the visual experience but also impedes usability and may lead to further issues if left unaddressed.
Swapping the screen restores the phone's functionality, ensuring a clear display, responsive touch, and preserving the overall user experience.
必要な工具と部品
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
Locate the battery in the middle of the back of the phone.
Push in and up on the battery to remove it from its slot.
Put the battery aside.
Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
What is left in your hand is now the screen, and any replacement screen will be just as what is in your hand.
