はじめに
The LED screen and touchscreen (digitizer) are one unit and make up the frame of the phone. You will essentially be removing all of the internal components of the phone and placing them in a new housing.
必要な工具と部品
Turn the device on it side with the buttons away from you.
Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
Remove the one T2 screw from the side of the phone near where the SIM card tray was.
Use a pair of tweezers to carefully pull up on the tape securing the connector.
This will undo the connector as well.
Starting at the bottom left corner of the battery, use the wide end of the spudger as a wedge to get underneath the battery.
Insert a plastic opening tool into the space created by the spudger and CAREFULLY begin to pry around the edge of the battery.
Once the battery is separated for enough from the phone, use your hands to fully remove the battery, using the wide end of the spudger to scrape off adhesive where necessary.
Using a set of tweezers, pull off the small piece of tape on top of the ribbon cable connector on the left side of the motherboard.
Use a spudger to pry up the the antenna connector on the top right of the charging port card.
Use a plastic opening tool to lift the lower connection cable, which is held on by adhesive, off of the phone frame.
12 の人々がこのガイドを完成させました。
2 件のコメント
Thanks! This helped loads with my repair.
Thanks for the tutorial. It helped a ton and was easy to follow. I would add the screen replacement from the frame portion of the assembly.
