パーツ
パーツは必要ありません。
  1. Using a spudger, remove the back panel of the phone.
    • Using a spudger, remove the back panel of the phone.
  2. Remove the battery and SD card from the phone. Remove the battery and SD card from the phone.
    • Remove the battery and SD card from the phone.
  3. Remove the five 4mm Philips #00 screws, circled in red, holding the the back down.
    • Remove the five 4mm Philips #00 screws, circled in red, holding the the back down.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Remove the back piece, exposing the motherboard.
    • Remove the back piece, exposing the motherboard.
  6. Flip up the three small tan clips holding the ribbons in place. Flip up the three small tan clips holding the ribbons in place. Flip up the three small tan clips holding the ribbons in place.
    • Flip up the three small tan clips holding the ribbons in place.
  7. Gently slide each of the three ribbons out of the motherboard.
    • Gently slide each of the three ribbons out of the motherboard.
  8. Slide the motherboard off of the ribbons detaching it from the front of the phone.
    • Slide the motherboard off of the ribbons detaching it from the front of the phone.
まとめ
6 の人々がこのガイドを完成させました。
Lilia Johnson
メンバー登録日: 2014年10月08日
650 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 9-5, Leahy Fall 2014 USF Tampa, Team 9-5, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S9G5
3 メンバー
5のガイドは作成済み
コメント1件
Zte blade a506 insert sim card problem
Ali Jaffar - 返信
統計データを表示:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 38
今までの合計 3,298
