メインコンテンツにスキップ
ZTE Axon11 Display Replacement
  1. ZTE Axon11 Display Replacement, Remove Back Cover: 手順 1、 1の画像 1
    • Remove the Back Cover as you would do with any other Mobile ..
  2. ZTE Axon11 Display Replacement: 手順 2、 1の画像 1
    • Get rid of Glue and plastic foils on top ..
  3. ZTE Axon11 Display Replacement: 手順 3、 1の画像 1
    • Unscrew lower cover Part (As far as i remember there have been 7 screws) and lift it up
  4. ZTE Axon11 Display Replacement: 手順 4、 1の画像 1
    • Under the cover part there is 1 screw left (this a tiny one, not like the other 7 ..)
  5. ZTE Axon11 Display Replacement: 手順 5、 2の画像 1 ZTE Axon11 Display Replacement: 手順 5、 2の画像 2
    • Then lift this part away as well ..
    • Unscrew all screws form the upper cover part near the camera ..
  6. ZTE Axon11 Display Replacement: 手順 6、 1の画像 1
    • Remove the battery. This is the hardest part. I tried from right side as seen in the Picture .. There are 2 flat cables on zthis side (connecting the motherboard and the lower electronics, so this might not be the best direction to start (see photos later). Try using fan (i did'nt have one) ..
    • The blue plastic shows the tiny screw which you need to unscrew to remove the whole upper plastic thing .. I'm not sure you need to remove that part to change the display ..
  7. ZTE Axon11 Display Replacement: 手順 7、 2の画像 1 ZTE Axon11 Display Replacement: 手順 7、 2の画像 2
    • This is the accu removed .. You can see that I damaged one of the flat cables (seem to work though) .. You can see where most of the glue has been, so concentrate your work on this area. The right flat cable is the connector to the display (the other two connect Motherboard and sideboard).. unconnect it ..
    • You can remove the other flat cables too (but don't have to ..).
  8. ZTE Axon11 Display Replacement: 手順 8、 1の画像 1
    • Remove the display form the front side .. Change the display, connect the flat cable as it has been .. Basically your are done now ..
    • Put everything back again ..
終わりに
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
作成者
1人の作成者と共同作成されました。
Andreas Behal
メンバー登録日: 11/02/21
169 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 45
今までの合計 672
