はじめに
Caution! Ribbons should NOT be torn when disassembling the motherboard from the phone! Use tweezers to GENTLY wiggle the ribbons back and forth to loosen and separate ribbons from the motherboard and phone.
  1. Remove the back cover of the phone to expose the phone's mid-frame.
    • Remove the back cover of the phone to expose the phone's mid-frame.
  2. Pry the battery up and out of the phone.
    • Pry the battery up and out of the phone.
  3. Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Wedge the flat end of the spudger between the mid frame and the digitizer. Wedge the flat end of the spudger between the mid frame and the digitizer. Wedge the flat end of the spudger between the mid frame and the digitizer.
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
  6. Gently pry the mid frame away from the rest of the phone to expose the motherboard. Gently pry the mid frame away from the rest of the phone to expose the motherboard.
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
  7. Use the tweezers to remove the four ribbon wires on the sides of the device. Use the tweezers to remove the four ribbon wires on the sides of the device. Use the tweezers to remove the four ribbon wires on the sides of the device.
    • Use the tweezers to remove the four ribbon wires on the sides of the device.
  8. Orient the motherboard to expose the mid frame.
    • Orient the motherboard to expose the mid frame.
  9. Remove the connector to free the motherboard from the screen. Remove the connector to free the motherboard from the screen. Remove the connector to free the motherboard from the screen.
    • Remove the connector to free the motherboard from the screen.
まとめ
5 の人々がこのガイドを完成させました。
Jennifer DeMeo
メンバー登録日: 2014年10月07日
960 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-2, Leahy Fall 2014 USF Tampa, Team 1-2, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S1G2
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 13
今までの合計 1,677
