はじめに
This guide will show you how to replace the camera in case it breaks or no longer works.
必要な工具と部品
Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws along the perimeter of the phone's mid frame.
Wedge the flat end of the spudger between the mid frame and the digitizer.
Gently pry the mid frame away from the rest of the phone to expose the motherboard.
ある他の人がこのガイドを完成しました。
