はじめに
In this guide, steps will be provided to remove and replace the left joystick on your ZD-N Plus Wireless Controller. The joystick might have to be replaced if the joystick is drifting, or if the joystick is not responding to your touch.
必要な工具と部品
Remove the electrical connector attaching each rumble motor to the controller.
Lift up on the circular section of the rumble to remove it from the controller.
Pull up on the left joystick to remove it from the motherboard. The plastic piece will unclip easily.
ある他の人がこのガイドを完成しました。
