メインコンテンツにスキップ
ZD-N Plus Wireless Controller LB and RB Buttons Replacement
必要な工具と部品
  1. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: 手順 2、 2の画像 1 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: 手順 2、 2の画像 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Battery: 手順 3、 1の画像 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: 手順 4、 2の画像 1 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: 手順 4、 2の画像 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: 手順 5、 2の画像 1 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: 手順 5、 2の画像 2
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Rumble Motor: 手順 6、 2の画像 1 ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Rumble Motor: 手順 6、 2の画像 2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
  7. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Motherboard: 手順 7、 2の画像 1 ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
  8. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: 手順 8、 1の画像 1
    • Lift the motherboard out of the controller.
  9. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, LB and RB Buttons: 手順 9、 1の画像 1
    • The LB/RB buttons can be easily pulled from the top of the controller.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Nick Aproff
メンバー登録日: 10/15/19
76 ポイント
1ガイドが承認済み
チーム
Grand Valley State University, Team S4-G1, DeVasto Fall 2019 Grand Valley State University, Team S4-G1, DeVasto Fall 2019人のメンバー
GVSU-DEVASTO-F19S4G1
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 21
今までの合計 609
