はじめに
Although professional grade drones are built to be robust, accidents and wear and tear may occur. Sometimes, it can be bad enough to cause the drone arm/motor to stop functioning, preventing operation of the drone. The drone arm suspends the propeller, allowing it to create lift for the drone unimpeded. Damage to this arm may prevent the propeller from working properly. This guide will show you how to replace a bad or broken drone arm on your Yuneec Typhoon H Plus drone. No special skills will be required to perform this replacement.
必要な工具と部品
ある他の人がこのガイドを完成しました。
