メインコンテンツにスキップ
Yuneec ST10 Plus Joystick Replacement
必要な工具と部品
  1. Yuneec ST10 Plus Joystick Replacement, Battery: 手順 1、 1の画像 1
    • Flip the controller upside down to access the battery compartment.
    • Grab the compartment door and pull down.
  2. Yuneec ST10 Plus Joystick Replacement: 手順 2、 1の画像 1
    • Gently lift the blue tab connected to the battery in order to remove the battery from its housing.
  3. Yuneec ST10 Plus Joystick Replacement: 手順 3、 3の画像 1 Yuneec ST10 Plus Joystick Replacement: 手順 3、 3の画像 2 Yuneec ST10 Plus Joystick Replacement: 手順 3、 3の画像 3
    • To disconnect the battery from the remote, grab the red and black connectors.
    • Pull gently on connectors until they disconnect.
  4. Yuneec ST10 Plus Joystick Replacement, Joystick Removal: 手順 4、 2の画像 1 Yuneec ST10 Plus Joystick Replacement, Joystick Removal: 手順 4、 2の画像 2
    • Slide the Jimmy underneath the rubber grips and pry upwards.
    • With your free hand grasp the rubber grips and pull upward to remove it.
  5. Yuneec ST10 Plus Joystick Replacement: 手順 5、 1の画像 1
    • Remove the six 1.3 cm screws located on the back panel of the remote using the 5.5mm hex screw bit.
  6. Yuneec ST10 Plus Joystick Replacement: 手順 6、 1の画像 1
    • Remove the four 6mm screws from the handle using the 4mm hex driver bit.
  7. Yuneec ST10 Plus Joystick Replacement: 手順 7、 2の画像 1 Yuneec ST10 Plus Joystick Replacement: 手順 7、 2の画像 2
    • Carefully pull up and over on the back panel to remove. Take your time because there are wires connecting the two panels that can be easily torn.
  8. Yuneec ST10 Plus Joystick Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use the nylon tipped tweezers to pull the two joystick cables from their connectors.
    • The cable connectors are located in the middle of the device and are inline with the two joysticks on the motherboard.
  9. Yuneec ST10 Plus Joystick Replacement: 手順 9、 1の画像 1
    • With the 5mm hex diver bit, remove the eight 10mm screws surrounding both joysticks.
  10. Yuneec ST10 Plus Joystick Replacement: 手順 10、 3の画像 1 Yuneec ST10 Plus Joystick Replacement: 手順 10、 3の画像 2 Yuneec ST10 Plus Joystick Replacement: 手順 10、 3の画像 3
    • Flip the controller back over.
    • Remove the joysticks.
ゴール
作成者
5人の作成者と共同で作成されました。
Joshua Collins
メンバー登録日: 01/27/20
586 ポイント
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 191
