はじめに
A faulty switch spring can lead to an unresponsive camera button, resulting in your controller not being able to record or take pictures. Cause of this can be dislocated spring, or as simple as the spring snapping over time. Follow these steps to replace the spring for either of the shoulder buttons on the Yuneec ST10 Plus drone controller.
必要な工具と部品
Flip the controller upside down to access the battery compartment.
Grab the compartment door and pull down.
Grab ahold of the top of the black cap on the button with the pliers and pull up forcefully.
Carefully pry up the small metal feet surrounding the red switch connector on both sides using a metal spudger.
この手順で使用する道具:Tweezers$3.99
With the angled tweezers pinch the end of the spring with the loop and gently push the spring down and back, then lift up.
Pinch the spring with the angled tweezers, bringing it to a vertical position. Then push down on the spring to remove it from the port that it is connected to.
Pull the spring away from the housing.
