メインコンテンツにスキップ
Yuneec Breeze 4K Motherboard Replacement
必要な工具と部品
  1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: 手順 1、 2の画像 1 Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: 手順 1、 2の画像 2
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Yuneec Breeze 4K Motherboard Replacement: 手順 2、 3の画像 1 Yuneec Breeze 4K Motherboard Replacement: 手順 2、 3の画像 2 Yuneec Breeze 4K Motherboard Replacement: 手順 2、 3の画像 3
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Yuneec Breeze 4K Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Yuneec Breeze 4K Motherboard Replacement: 手順 4、 1の画像 1
    • Unplug the four cables that are connected on the top face of the frame.
  5. Yuneec Breeze 4K Motherboard Replacement: 手順 5、 2の画像 1 Yuneec Breeze 4K Motherboard Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  6. Yuneec Breeze 4K Motherboard Replacement: 手順 6、 3の画像 1 Yuneec Breeze 4K Motherboard Replacement: 手順 6、 3の画像 2 Yuneec Breeze 4K Motherboard Replacement: 手順 6、 3の画像 3
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  7. Yuneec Breeze 4K Motherboard Replacement: 手順 7、 3の画像 1 Yuneec Breeze 4K Motherboard Replacement: 手順 7、 3の画像 2 Yuneec Breeze 4K Motherboard Replacement: 手順 7、 3の画像 3
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  8. Yuneec Breeze 4K Motherboard Replacement: 手順 8、 1の画像 1
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  9. Yuneec Breeze 4K Motherboard Replacement: 手順 9、 2の画像 1 Yuneec Breeze 4K Motherboard Replacement: 手順 9、 2の画像 2
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ryanne Millis
メンバー登録日: 10/04/18
318 ポイント
1ガイドが承認済み
チーム
UW Stout, Team S6-G5, Ogden Fall 2018 UW Stout, Team S6-G5, Ogden Fall 2018人のメンバー
UWSTOUT-OGDEN-F18S6G5
4 メンバー
4のガイドは作成済み
コメント 1 件
Excellent step by step instructions.
paul_courville - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 2,041
