メインコンテンツにスキップ
Yuneec Breeze 4K Camera Replacement
必要な工具と部品
  1. Yuneec Breeze 4K Camera Replacement, Camera: 手順 1、 2の画像 1 Yuneec Breeze 4K Camera Replacement, Camera: 手順 1、 2の画像 2
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Once the battery is taken out, flip over the drone so that the cameras are now facing up.
  2. Yuneec Breeze 4K Camera Replacement: 手順 2、 1の画像 1
    • Using small pliers grip the connector of the wire and pull it out slowly.
  3. Yuneec Breeze 4K Camera Replacement: 手順 3、 1の画像 1
    • Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
  4. Yuneec Breeze 4K Camera Replacement: 手順 4、 1の画像 1
    • Unplug the two vertical plugs located in the rear of the M7 board.
  5. Yuneec Breeze 4K Camera Replacement: 手順 5、 1の画像 1
    • Slightly lift the M7 board to remove the two plugs located under the rear of the board.
  6. Yuneec Breeze 4K Camera Replacement: 手順 6、 1の画像 1
    • Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
  7. Yuneec Breeze 4K Camera Replacement: 手順 7、 2の画像 1 Yuneec Breeze 4K Camera Replacement: 手順 7、 2の画像 2
    • Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
  8. Yuneec Breeze 4K Camera Replacement: 手順 8、 1の画像 1
    • Using a pair of pliers pull apart the battery connector.
  9. Yuneec Breeze 4K Camera Replacement: 手順 9、 1の画像 1
    • Flip over the entire frame along with the M7 board and the A9 board.
  10. Yuneec Breeze 4K Camera Replacement: 手順 10、 1の画像 1
    • There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
  11. Yuneec Breeze 4K Camera Replacement: 手順 11、 1の画像 1
    • Unplug the only wire that is connected to the A9 board.
  12. Yuneec Breeze 4K Camera Replacement: 手順 12、 1の画像 1
    • Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
  13. Yuneec Breeze 4K Camera Replacement: 手順 13、 1の画像 1
    • Unscrew the four screws that are holding the camera to the frame.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Wes Knutson
メンバー登録日: 10/04/18
481 ポイント
3のガイドは作成済み
チーム
UW Stout, Team S6-G5, Ogden Fall 2018 UW Stout, Team S6-G5, Ogden Fall 2018人のメンバー
UWSTOUT-OGDEN-F18S6G5
4 メンバー
4のガイドは作成済み
コメント 1 件
Excellent! I don’t think that the process could of have been any more clear than this.
neonjohn25 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,928
