メインコンテンツにスキップ
Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt
必要な工具と部品
  1. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Rear Casing: 手順 1、 2の画像 1 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Rear Casing: 手順 1、 2の画像 2
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 2、 3の画像 1 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 2、 3の画像 2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 2、 3の画像 3
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 3、 3の画像 1 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 3、 3の画像 2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 3、 3の画像 3
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 4、 2の画像 1 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 4、 2の画像 2
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
  5. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Wiring: 手順 5、 2の画像 1 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Wiring: 手順 5、 2の画像 2
    • Use the metal spudger to bend down the metal tabs that hold the wires to the terminals. The tabs are small and in between the grooves of the terminal.
  6. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 6、 2の画像 1 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 6、 2の画像 2
    • Remove the wires from the terminals.
  7. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 7、 2の画像 1 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 7、 2の画像 2
    • Use the metal spudger to bend the metal tabs that hold the connectors to the terminals.
  8. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 8、 3の画像 1 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 8、 3の画像 2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 手順 8、 3の画像 3
    • Remove the wires from the terminals. Then remove the entire wire assembly.
  9. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Front Panel and Speaker Housing: 手順 9、 1の画像 1
    • Once the wire assembly is removed, the entire front panel and speaker housing should be separated to replace.
終わりに
作成者
3人の作成者と共同で作成されました。
Nick Ruiz
メンバー登録日: 02/07/17
331 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 17-3, Blackwell Spring 2017 USF Tampa, Team 17-3, Blackwell Spring 2017人のメンバー
USFT-BLACKWELL-S17S17G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 1,502
