メインコンテンツにスキップ
はじめに
This guide explains the method to repair or replace damaged wires on the Yamaha NS‑AW190BL.
パーツ
パーツは指定されていません。
  1. Remove the six Phillips Head 1.2mm screws on the front side of the speaker. Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Crack open both parts of the casing carefully. Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker. Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Remove the cooling foam. Use a metal spudger to push the tab in on the red wire. Repeat the process for the blue wire.
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. The blue wire can now be removed from its connector. Remove the red wire to free the rear casing.
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
  5. Use the metal spudger to bend down the metal tabs that hold the wires to the terminals.  The tabs  are small and in between the grooves of the terminal. Use the metal spudger to bend down the metal tabs that hold the wires to the terminals.  The tabs  are small and in between the grooves of the terminal.
    • Use the metal spudger to bend down the metal tabs that hold the wires to the terminals. The tabs are small and in between the grooves of the terminal.
  6. Remove the wires from the terminals. Remove the wires from the terminals.
    • Remove the wires from the terminals.
  7. Use the metal spudger to bend the metal tabs that hold the connectors to the terminals. Use the metal spudger to bend the metal tabs that hold the connectors to the terminals.
    • Use the metal spudger to bend the metal tabs that hold the connectors to the terminals.
  8. Remove the wires from the terminals. Then remove the entire wire assembly. Remove the wires from the terminals. Then remove the entire wire assembly. Remove the wires from the terminals. Then remove the entire wire assembly.
    • Remove the wires from the terminals. Then remove the entire wire assembly.
終わりに
Roshal Robince
メンバー登録日: 2017年02月07日
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 17-3, Blackwell Spring 2017 USF Tampa, Team 17-3, Blackwell Spring 2017人のメンバー
USFT-BLACKWELL-S17S17G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 450
