メインコンテンツにスキップ
Yamaha DM1000 Faders Replacement
必要な工具と部品
  1. Yamaha DM1000 Faders Replacement, Remove wood  panels (Assuming you have it): 手順 1、 2の画像 1 Yamaha DM1000 Faders Replacement, Remove wood  panels (Assuming you have it): 手順 1、 2の画像 2
    • Remove 5 screws:
    • Three screws for the lower part
    • Two screws for the upper part
    • Use a #4 Phillips screwdriver.
  2. Yamaha DM1000 Faders Replacement, Remove meter (if you have one): 手順 2、 2の画像 1 Yamaha DM1000 Faders Replacement, Remove meter (if you have one): 手順 2、 2の画像 2
    • Remove sub-d connector from bargraph.
    • Remove 4 screws (2shorts/2 long) from metal bracket and mixing desk.
  3. Yamaha DM1000 Faders Replacement, Remove side panels: 手順 3、 1の画像 1
    • Remove 15 screws:
    • Remove 1 smaller screw
    • remove Phillip screw #2
    • Attention: these are self-tapping screws => risk of creating chips when screwing.
  4. Yamaha DM1000 Faders Replacement, Remove fader button + front & back screws: 手順 4、 3の画像 1 Yamaha DM1000 Faders Replacement, Remove fader button + front & back screws: 手順 4、 3の画像 2 Yamaha DM1000 Faders Replacement, Remove fader button + front & back screws: 手順 4、 3の画像 3
    • remove 16 + 1 fader with fingers or a with a plastic card.
    • remove 4 screws at the back.
    • remove 4 screws at the front (bad pic here).
  5. Yamaha DM1000 Faders Replacement, Remove 4 cables before opening: 手順 5、 2の画像 1 Yamaha DM1000 Faders Replacement, Remove 4 cables before opening: 手順 5、 2の画像 2
    • remove carrefully from the side the 2 withe connectors.
    • remove carrefully 2 cables from the power unit, unlock first the connector.
  6. Yamaha DM1000 Faders Replacement, Opening the  console: 手順 6、 3の画像 1 Yamaha DM1000 Faders Replacement, Opening the  console: 手順 6、 3の画像 2 Yamaha DM1000 Faders Replacement, Opening the  console: 手順 6、 3の画像 3
    • open carefully the console from back to front by graping the sides.
    • open connectors and remove 5 cables.
    • you can now remove the upper part of the console.
  7. Yamaha DM1000 Faders Replacement, Removing the circuit board: 手順 7、 3の画像 1 Yamaha DM1000 Faders Replacement, Removing the circuit board: 手順 7、 3の画像 2 Yamaha DM1000 Faders Replacement, Removing the circuit board: 手順 7、 3の画像 3
    • Cut the plastic clamps. Their are 4 clamps in the corners and 1 clamp holding flat cable in place.
    • Unscrew the 10 screws with a Phillips #2 screwdriver.
  8. Yamaha DM1000 Faders Replacement, Removing Fader  cover: 手順 8、 1の画像 1
    • For each fader remove the 2 blacks screws with a philips #2.
  9. Yamaha DM1000 Faders Replacement, Remove  cover + fader: 手順 9、 2の画像 1 Yamaha DM1000 Faders Replacement, Remove  cover + fader: 手順 9、 2の画像 2
    • remove solder from 4 metal bracket that are fixed to the PCB from the cover.
    • remove solder with a pump from 6 pin of the fader.
    • remove solder from the 2 pin of the motor of the fader.
  10. Yamaha DM1000 Faders Replacement, Replace transistors: 手順 10、 1の画像 1
    • Replace transistors by new ones.
    • 2SB1181.
    • 2SD1733.
    • they are hard to find as the are being obsolete.
  11. Yamaha DM1000 Faders Replacement, Add more  reliability: 手順 11、 1の画像 1
    • An idea from web forum from a Yamaha Technician that propose to add 4X 1N4148 diode by fader to protect the transistor. as free wheel.
    • add diode between base and collector as show here.
終わりに
To reassemble your device follow the following instructions in reverse order.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
F. Jeanneret
メンバー登録日: 12/27/17
248 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 54
今までの合計 2,029
