メインコンテンツにスキップ
XtremeMac Luna Radio Jack Replacement
必要な工具と部品
  1. XtremeMac Luna Radio Jack Replacement, Bottom Panel: 手順 1、 3の画像 1 XtremeMac Luna Radio Jack Replacement, Bottom Panel: 手順 1、 3の画像 2 XtremeMac Luna Radio Jack Replacement, Bottom Panel: 手順 1、 3の画像 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Radio Jack Replacement: 手順 2、 1の画像 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Radio Jack Replacement: 手順 3、 2の画像 1 XtremeMac Luna Radio Jack Replacement: 手順 3、 2の画像 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Radio Jack Replacement, Dock Circuit Board: 手順 4、 3の画像 1 XtremeMac Luna Radio Jack Replacement, Dock Circuit Board: 手順 4、 3の画像 2 XtremeMac Luna Radio Jack Replacement, Dock Circuit Board: 手順 4、 3の画像 3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
  5. XtremeMac Luna Radio Jack Replacement, Button Circuit Boards: 手順 5、 2の画像 1 XtremeMac Luna Radio Jack Replacement, Button Circuit Boards: 手順 5、 2の画像 2
    • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
    • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
  6. XtremeMac Luna Radio Jack Replacement: 手順 6、 3の画像 1 XtremeMac Luna Radio Jack Replacement: 手順 6、 3の画像 2 XtremeMac Luna Radio Jack Replacement: 手順 6、 3の画像 3
    • Use a plastic opening tool to pry the black connections away from the top casing.
    • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
  7. XtremeMac Luna Radio Jack Replacement: 手順 7、 2の画像 1 XtremeMac Luna Radio Jack Replacement: 手順 7、 2の画像 2
    • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
    • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
  8. XtremeMac Luna Radio Jack Replacement, Radio Jack: 手順 8、 1の画像 1
    • Remove the two 12mm Phillips head screws from the back of the device using a Phillips #1 screwdriver.
  9. XtremeMac Luna Radio Jack Replacement: 手順 9、 2の画像 1 XtremeMac Luna Radio Jack Replacement: 手順 9、 2の画像 2
    • Turn the Luna so that the display faces forward.
    • Pull the two white tabs to remove the cables from the front of the radio jack.
  10. XtremeMac Luna Radio Jack Replacement: 手順 10、 2の画像 1 XtremeMac Luna Radio Jack Replacement: 手順 10、 2の画像 2
    • Push the connections through the back casing and lift the radio jack up and out.
    • Reinserting the square AM switches can be tricky. Make sure they are aligned properly when you are reassembling the device.
  11. XtremeMac Luna Radio Jack Replacement: 手順 11、 2の画像 1 XtremeMac Luna Radio Jack Replacement: 手順 11、 2の画像 2
    • Desolder the positive connection (red) and the negative connection (black) on top of the radio jack to completely remove it.
終わりに
作成者
4人の作成者と共同で作成されました。
David Ellison
メンバー登録日: 04/18/13
18 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-47, Amido Spring 2013 Cal Poly, Team 3-47, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G47
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 10
今までの合計 370
