メインコンテンツにスキップ
XtremeMac Luna Alarm Buttons Replacement
必要な工具と部品
  1. XtremeMac Luna Alarm Buttons Replacement, Bottom Panel: 手順 1、 3の画像 1 XtremeMac Luna Alarm Buttons Replacement, Bottom Panel: 手順 1、 3の画像 2 XtremeMac Luna Alarm Buttons Replacement, Bottom Panel: 手順 1、 3の画像 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Alarm Buttons Replacement: 手順 2、 1の画像 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Alarm Buttons Replacement: 手順 3、 2の画像 1 XtremeMac Luna Alarm Buttons Replacement: 手順 3、 2の画像 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Alarm Buttons Replacement, Dock Circuit Board: 手順 4、 3の画像 1 XtremeMac Luna Alarm Buttons Replacement, Dock Circuit Board: 手順 4、 3の画像 2 XtremeMac Luna Alarm Buttons Replacement, Dock Circuit Board: 手順 4、 3の画像 3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
  5. XtremeMac Luna Alarm Buttons Replacement, Button Circuit Boards: 手順 5、 2の画像 1 XtremeMac Luna Alarm Buttons Replacement, Button Circuit Boards: 手順 5、 2の画像 2
    • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
    • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
  6. XtremeMac Luna Alarm Buttons Replacement: 手順 6、 3の画像 1 XtremeMac Luna Alarm Buttons Replacement: 手順 6、 3の画像 2 XtremeMac Luna Alarm Buttons Replacement: 手順 6、 3の画像 3
    • Use a plastic opening tool to pry the black connections away from the top casing.
    • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
  7. XtremeMac Luna Alarm Buttons Replacement: 手順 7、 2の画像 1 XtremeMac Luna Alarm Buttons Replacement: 手順 7、 2の画像 2
    • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
    • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
  8. XtremeMac Luna Alarm Buttons Replacement, Alarm Buttons: 手順 8、 2の画像 1 XtremeMac Luna Alarm Buttons Replacement, Alarm Buttons: 手順 8、 2の画像 2
    • Press the green tabs on the underside of the top case together and push them through the plastic casing.
    • Turn the top casing right side up and remove the button and spring.
終わりに
作成者
3人の作成者と共同で作成されました。
David Ellison
メンバー登録日: 04/18/13
18 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-47, Amido Spring 2013 Cal Poly, Team 3-47, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G47
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 9
今までの合計 371
