はじめに
If your camera's back case is damaged, you might consider changing it. To remove the back panel you will need a small blue plastic opening tool.
必要な工具と部品
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
10 の人々がこのガイドを完成させました。
2 Guide Comments
Where can i buy the back panel replacement ?
