はじめに
This guide will show how to replace the headphone jack. This guide requires soldering and desoldering the part.
必要な工具と部品
Insert the plastic opening tool between the charging port and the rear case.
Pry the end of the rear case up from the charging port.
Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
Run the plastic opening tool along the seam.
Pry up the midframe with the plastic opening tool.
Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
Use tweezers to pull the ribbon cable out of the ZIF connector.
Remove the front-facing camera from the motherboard.
Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
Flip over the motherboard and locate the headphone jack at the top left corner.
Desolder the 6 soldered connections on the sides of the headphone jack from the motherboard.
7 の人々がこのガイドを完成させました。
6 件のコメント
You have mentioned it in detailed, but can you mentioned the actual way or sequence of soldering six legs of the jack?
Can you mention the part number of redmi note headphone jack?
link where the jack will be available.
I want to buy head phone jack, where the jack will
You can visit iSparehub.com
Hey, hast du eine Ahnung, wo man eine Kopfhörerbuchse als Ersatzteil für ein Xiaomi Redmi Note 5 Global herbekommt? Das wäre klasse.
Redmi note 4 earphone jack replacement Ka price Kya hai
