はじめに
This guide will show you how to replace the front-facing "selfie" camera on your Xiaomi Redmi Note.
必要な工具と部品
Insert the plastic opening tool between the charging port and the rear case.
Pry the end of the rear case up from the charging port.
Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
Run the plastic opening tool along the seam.
Pry up the midframe with the plastic opening tool.
Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
この手順で使用する道具:Tweezers$4.99
Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
Use tweezers to pull the ribbon cable out of the ZIF connector.
Remove the front-facing camera from the motherboard.
2 の人々がこのガイドを完成させました。
