メインコンテンツにスキップ
Xiaomi Redmi 2 Ambient Light Sensor Replacement
必要な工具と部品
  1. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: 手順 1、 2の画像 1 Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: 手順 1、 2の画像 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 2、 1の画像 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 3、 1の画像 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 4、 1の画像 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 5、 1の画像 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 6、 2の画像 1 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 7、 2の画像 1 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 7、 2の画像 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 8、 2の画像 1 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 8、 2の画像 2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 9、 2の画像 1 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 9、 2の画像 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 10、 2の画像 1 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 10、 2の画像 2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 11、 1の画像 1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Ambient Light Sensor: 手順 12、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using one prong of the tweezers, lift and loosen the edge of the ambient light sensor from the motherboard.
  13. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 手順 13、 1の画像 1
    • Using your fingers, gently pull out the ambient light sensor.
終わりに
17 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alicia Brenner
メンバー登録日: 10/01/15
3,539 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015人のメンバー
USFT-LEAHY-F15S1G3
2 メンバー
5のガイドは作成済み
コメント 1 件
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 5,287
