メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Use this guide to remove the headphone jack from your Xiaomi Mi Pad.
パーツ
パーツは指定されていません。
  1. Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device.  Work your way around the device, slowly increasing the gap. The back panel has small clips and light adhesive that easily releases from the device.
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  4. Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device. Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  5. Remove the upper cover from the device.
    • Remove the upper cover from the device.
  6. Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Insert the corner of a plastic opening tool into the port of the headphone jack for easier removal.
終わりに
ある他の人がこのガイドを完成しました。
Rene Mendoza
メンバー登録日: 2015年09月03日
311 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S12G5
3 メンバー
12のガイドは作成済み
コメント1件
And where to buy? :-(
marcusvoag - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,203
