メインコンテンツにスキップ
Xiaomi Mi Pad Battery Replacement
必要な工具と部品
  1. Xiaomi Mi Pad Battery Replacement, Rear Case Assembly: 手順 1、 1の画像 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Battery Replacement: 手順 2、 2の画像 1 Xiaomi Mi Pad Battery Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Battery Replacement, Battery: 手順 3、 2の画像 1 Xiaomi Mi Pad Battery Replacement, Battery: 手順 3、 2の画像 2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Battery Replacement: 手順 4、 1の画像 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Battery Replacement: 手順 5、 2の画像 1 Xiaomi Mi Pad Battery Replacement: 手順 5、 2の画像 2
    • Use a plastic opening tool to disconnect the three ribbon cable connectors.
    • If you're only going to replace the battery, you should only need to disconnect the smallest ribbon cable that connects the battery to the motherboard.
  6. Xiaomi Mi Pad Battery Replacement: 手順 6、 1の画像 1
    • Carefully pry around the perimeter of the battery with a plastic opening tool to loosen the adhesive securing the battery to the device.
    • Be gentle when removing the battery, as lithium-ion batteries should not be bent or punctured.
  7. Xiaomi Mi Pad Battery Replacement: 手順 7、 3の画像 1 Xiaomi Mi Pad Battery Replacement: 手順 7、 3の画像 2 Xiaomi Mi Pad Battery Replacement: 手順 7、 3の画像 3
    • If you disconnected all three connectors, the charging port ribbon cable may have a small amount of adhesive securing it to the battery. Gently pry the cable free of the battery and lift the battery up and out of the device.
終わりに
18 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jessica
メンバー登録日: 09/03/15
713 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S12G5
3 メンバー
13のガイドは作成済み
12 件のコメント
Hi
Great Tutorial, but where can i buy a replacement Battery?
THANKS
Marcel - 返信
Go to Leamington road and you will get it
affan -
Go to Leamington road mumbai
affan -
Where to purchase the Mi Paf battery?
Dino Bay - 返信
Please please make a video for it. I need it desperately.
Man Mohan Shukla - 返信
It is not so easy when u have a deal with factory battery. I think guide tell us about replace battery not first time ;)
tsyba1980 - 返信
Can somebody tell about replacement charge jack on this device?
tsyba1980 - 返信
Where can I get brand new mi tablet battery in india?
Saurabh saindane - 返信
Step 3: got 2 screws cover with orange Mi sticker. Don’t forget to unscrew them.
Step 6: got tape stick behind the battery, very sticky. Need remove gently and slowly.
Other work very well, thanks for the tutorial. Successfully replace my Mi Pad battery.
Andy Teoh - 返信
What sort is brand for light adhesive (glue)?
Vitaly Titov - 返信
Need the female connector for battery. This soldered to board.
By accident was destroyed and want to change it…
How know the part number ? and can help.
Dino
Dino Solomon - 返信
My mipad not starting after battery replacement. Red light blinks 2 times and shows MI logo then turn off… but boots perfect with old battery. How do i resolve this issue?
brahmasoor anirudhan - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 110
今までの合計 23,424
