メインコンテンツにスキップ
Xiaomi Mi A2 Screen Replacement
必要な工具と部品
  1. Xiaomi Mi A2 Screen Replacement, Screen: 手順 1、 2の画像 1 Xiaomi Mi A2 Screen Replacement, Screen: 手順 1、 2の画像 2
    • Turn off your phone before proceeding.
    • Remove SIM card tray from phone.
    • Touch something metallic to ensure you are electrostatic safe.
  2. Xiaomi Mi A2 Screen Replacement: 手順 2、 1の画像 1
    • Remove the two 2.7mm Pentalobe #2 screws from the bottom of the phone.
  3. Xiaomi Mi A2 Screen Replacement: 手順 3、 3の画像 1 Xiaomi Mi A2 Screen Replacement: 手順 3、 3の画像 2 Xiaomi Mi A2 Screen Replacement: 手順 3、 3の画像 3
    • Grab a suction cup tool and place it near the bottom of the phone.
    • Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
    • Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
    • Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
    • Flip the phone screen towards the bottom of the device and lay the screen facing down.
    • Note: The ribbon cable is in the middle of the panel, thus there is no need to be cautious about snagging a ribbon cable
  4. Xiaomi Mi A2 Screen Replacement: 手順 4、 2の画像 1 Xiaomi Mi A2 Screen Replacement: 手順 4、 2の画像 2
    • When removing the ribbon cable and installing the new one take special care to not bend or fold the cable too much as this can cause damage to the cable itself.
    • To access the ribbon cable connectors we must remove the metal bracket.
    • Remove the three 2.4mm Philips #0 screws that hold the panel down.
  5. Xiaomi Mi A2 Screen Replacement: 手順 5、 3の画像 1 Xiaomi Mi A2 Screen Replacement: 手順 5、 3の画像 2 Xiaomi Mi A2 Screen Replacement: 手順 5、 3の画像 3
    • Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
    • Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
    • After you remove the ribbon cable the panel should be free to remove and replace.
終わりに
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Victor Sanchez Gutierrez
メンバー登録日: 09/30/19
685 ポイント
1ガイドが承認済み
チーム
UC Santa Barbara, Team S27-G27, Nowak Fall 2019 UC Santa Barbara, Team S27-G27, Nowak Fall 2019人のメンバー
UCSB-NOWAK-F19S27G27
1 メンバー
3のガイドは作成済み
コメント 1 件
Great guide, thanks!
The only thing, on step # 3 make sure you are removing both frame and display.
First time I by mistake removed display only, and saw quite a different internals (no battery, etc).
AI Mechanic - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 29
過去 30 日: 154
今までの合計 13,268
