はじめに
Use this guide to remove or replace a malfunctioning or defective loudspeaker unit in the Xiaomi Mi 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
Remove the seven Phillips #00 screws securing the loudspeaker unit:
Four silver 3.2 mm long screws
Two yellowish 3.8 mm long screws
One black 2.8 mm long screw
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
4 の人々がこのガイドを完成させました。
