この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
この手順で使用する道具:Metal Spudger$2.99-
Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
Using the second spudger, slowly work your way around the perimeter of the device
As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
この手順は未翻訳です。 翻訳を手伝う。
Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
この手順は未翻訳です。 翻訳を手伝う。
この手順で使用する道具:Tweezers$4.99-
Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
Proceed to gently remove the tape like connector from the battery until it is completely off.
Use tweezer to disconnect battery’s wire from the motherboard.
48 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
16%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
24 件のコメント
Sir, I accidentally put a hole in battery while removing. Will this create a problem/explosion..
Hey Apawilo. A punctured battery has potential to be very dangerous (Fire, harmful chemicals, etc), so please make sure to dispose of it at the nearest e-waste recycling site.
sir i am charging my phone but its percentage is not increasing ....this is a battery problem
im having the similar problem, when charging power increase slower and the consumption is faster than usual. please advice. thanks
Zeff Soo -
