メインコンテンツにスキップ
Xiaomi Mi 3 Side control buttons Replacement
必要な工具と部品
  1. Xiaomi Mi 3 Side control buttons Replacement, Battery: 手順 1、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement, Battery: 手順 1、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement, Battery: 手順 1、 3の画像 3
    • Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
  2. Xiaomi Mi 3 Side control buttons Replacement: 手順 2、 2の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 2、 2の画像 2
    • Remove the two Phillips head screws located at the top of the phone on either side where the SIM card was ejected.
    • One screw is located under an orange sticker which would serve as your warranty for the camera were this practice not illegal as per the Magnuson–Moss Warranty Act of 1975.
  3. Xiaomi Mi 3 Side control buttons Replacement: 手順 3、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 3、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 3、 3の画像 3
    • Insert a pry tool into the upper edge of the phone, where there is a small gap between screen and frame of the phone to begin separating the screen from the rest of the phone.
    • Be careful when using the pry tool as it can damage the phone's screen or other components.
  4. Xiaomi Mi 3 Side control buttons Replacement: 手順 4、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 4、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 4、 3の画像 3
    • Once the pry tool has been inserted into the phone, slide it around the perimeter of the phone while gently lifting until the screen panel and back panel of the phone separate.
  5. Xiaomi Mi 3 Side control buttons Replacement: 手順 5、 2の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 5、 2の画像 2
    • The back of the phone should now be separated from the screen.
  6. Xiaomi Mi 3 Side control buttons Replacement: 手順 6、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 6、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Place the front panel screen side down with the camera at the top.
    • Remove these six Phillips head screws located at the upper half of the phone.
    • This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
  7. Xiaomi Mi 3 Side control buttons Replacement: 手順 7、 1の画像 1
    • Next, remove these three screws located at the bottom of the back panel.
  8. Xiaomi Mi 3 Side control buttons Replacement: 手順 8、 2の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 8、 2の画像 2
    • Using tweezers, remove the rubber dust cover on the back panel of the phone.
  9. Xiaomi Mi 3 Side control buttons Replacement: 手順 9、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 9、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 9、 3の画像 3
    • Remove the plastic cover on the bottom of the back panel by inserting the pry tool at the edge and gently lifting.
  10. Xiaomi Mi 3 Side control buttons Replacement: 手順 10、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 10、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 10、 3の画像 3
    • Remove the upper plastic cover from the back panel by inserting the pry tool into the upper edge and gently lifting.
    • Some models have the NFC antenna at the back of the battery glued to the top cover. It is not possible to remove the top cover without removing the battery as well. For these models, check the touchscreen guide for instructions.
  11. Xiaomi Mi 3 Side control buttons Replacement: 手順 11、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 11、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 11、 3の画像 3
    • Using a spudger, remove the small ribbon cable that is connected to the battery.
  12. Xiaomi Mi 3 Side control buttons Replacement: 手順 12、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 12、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 12、 3の画像 3
    • Remove the battery by gripping and pull up on the "Battery Removal" tab attached to the left side of the battery on the back panel.
    • Some force may be required to remove the battery since it is adhered to the phone with two pieces of double sided tape.
  13. Xiaomi Mi 3 Side control buttons Replacement: 手順 13、 1の画像 1
    • The battery is now removed from the panel.
  14. Xiaomi Mi 3 Side control buttons Replacement, Motherboard: 手順 14、 2の画像 1 Xiaomi Mi 3 Side control buttons Replacement, Motherboard: 手順 14、 2の画像 2
    • Disconnect the antenna wire that is attached to the lower left side of the motherboard using the pry tool.
  15. Xiaomi Mi 3 Side control buttons Replacement: 手順 15、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 15、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 15、 3の画像 3
    • Use a pry tool to separate the LCD display cable from the motherboard. The cable connects to the motherboard as a rectangular metallic piece at the bottom right of the motherboard.
  16. Xiaomi Mi 3 Side control buttons Replacement: 手順 16、 2の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 16、 2の画像 2
    • Disconnect the gold ribbon cable for the LCD display by gently inserting the pry tool under the wide end and lifting up.
  17. Xiaomi Mi 3 Side control buttons Replacement: 手順 17、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 17、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 17、 3の画像 3
    • Separate a cable ribbon from the top right of the motherboard by gently inserting the pry tool under the rectangular metallic piece and lifting.
  18. Xiaomi Mi 3 Side control buttons Replacement: 手順 18、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 18、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 18、 3の画像 3
    • Separate a cable ribbon from the top right of the motherboard - near the cable from the previous step - by gently inserting the pry tool under the rectangular metallic piece and lifting.
  19. Xiaomi Mi 3 Side control buttons Replacement: 手順 19、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 19、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 19、 3の画像 3
    • Using a pry tool, gently lift the side control buttons assembly away from the case. They should be loosely connected to the motherboard.
  20. Xiaomi Mi 3 Side control buttons Replacement: 手順 20、 2の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 20、 2の画像 2
    • Remove these two screws.
  21. Xiaomi Mi 3 Side control buttons Replacement: 手順 21、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement: 手順 21、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement: 手順 21、 3の画像 3
    • Remove the motherboard from the panel carefully. Use the pry tool as a lever from the top of the panel and lift if from that side.
  22. Xiaomi Mi 3 Side control buttons Replacement: 手順 22、 1の画像 1
    • The motherboard has now been successfully removed.
  23. Xiaomi Mi 3 Side control buttons Replacement, Side control buttons: 手順 23、 3の画像 1 Xiaomi Mi 3 Side control buttons Replacement, Side control buttons: 手順 23、 3の画像 2 Xiaomi Mi 3 Side control buttons Replacement, Side control buttons: 手順 23、 3の画像 3
    • With the motherboard removed flip it over onto its front and use a small pry tool to gently disconnect the side buttons from the back of the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Tyler Howard
メンバー登録日: 09/02/15
705 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-5, Remmell Fall 2015 USF Tampa, Team 1-5, Remmell Fall 2015人のメンバー
USFT-REMMELL-F15S1G5
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 22
今までの合計 2,662
