必要な工具と部品
Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
Place the front panel screen side down with the camera at the top.
Remove these six Phillips head screws located at the upper half of the phone.
This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
Disconnect the antenna wire that is attached to the lower left side of the motherboard using the pry tool.
With the motherboard removed you can use tweezers to remove the vibrator rather easily.
3 の人々がこのガイドを完成させました。
