メインコンテンツにスキップ
Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement
必要な工具と部品
  1. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 手順 1、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 手順 1、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 手順 1、 3の画像 3
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 手順 2、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 手順 2、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 手順 2、 3の画像 3
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 手順 3、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 手順 3、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 手順 3、 3の画像 3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 手順 4、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 手順 4、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 手順 4、 3の画像 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 手順 5、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 手順 5、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 手順 5、 3の画像 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 手順 6、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 手順 6、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 手順 6、 3の画像 3
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 手順 7、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 手順 7、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 手順 7、 3の画像 3
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 手順 8、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 手順 8、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 手順 8、 3の画像 3
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Reposition the battery compartment sticker: 手順 9、 2の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Reposition the battery compartment sticker: 手順 9、 2の画像 2
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Unfasten the top housing: 手順 10、 2の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Unfasten the top housing: 手順 10、 2の画像 2
    • Use a Torx T8 Security screwdriver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 手順 11、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 手順 11、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 手順 11、 3の画像 3
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 手順 12、 3の画像 1 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 手順 12、 3の画像 2 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 手順 12、 3の画像 3
    • Use your fingers to remove the joystick covers.
終わりに
5 の人々がこのガイドを完成させました。
Manuel Haeussermann
メンバー登録日: 07/13/22
14,256 ポイント
71のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
16,257のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 91
過去 30 日: 421
今までの合計 2,614
