メインコンテンツにスキップ
Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement
必要な工具と部品
  1. Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Insert an opening tool: 手順 1、 3の画像 1 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Insert an opening tool: 手順 1、 3の画像 2 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Insert an opening tool: 手順 1、 3の画像 3
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Release the right handle cover clips: 手順 2、 3の画像 1 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Release the right handle cover clips: 手順 2、 3の画像 2 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Release the right handle cover clips: 手順 2、 3の画像 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Remove the right handle cover: 手順 3、 3の画像 1 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Remove the right handle cover: 手順 3、 3の画像 2 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Remove the right handle cover: 手順 3、 3の画像 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
終わりに
Manuel Haeussermann
メンバー登録日: 07/13/22
14,256 ポイント
71のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
16,255のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 62
今までの合計 398
