メインコンテンツにスキップ
Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement
必要な工具と部品
  1. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 手順 1、 3の画像 1 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 手順 1、 3の画像 2 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 手順 1、 3の画像 3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 手順 2、 3の画像 1 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 手順 2、 3の画像 2 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 手順 2、 3の画像 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 手順 3、 3の画像 1 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 手順 3、 3の画像 2 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 手順 3、 3の画像 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Manuel Haeussermann
メンバー登録日: 07/13/22
15,592 ポイント
71のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,291のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 98
今までの合計 1,171
