はじめに
This guide can be used to fix the first generation of Xbox. When taking the Xbox apart to replace the fan make sure to be careful in carefully following all of the steps to ensure that you can put it back together properly.
必要な工具と部品
ビデオの概要
Turn the Xbox on its back and remove the rubber feet in each corner using a flathead screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
