メインコンテンツにスキップ
Xbox One X Project Scorpio Edition HDD to SSD Replacement
必要な工具と部品
  1. Xbox One X Project Scorpio Edition HDD to SSD Replacement, Outer Case: 手順 1、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement, Outer Case: 手順 1、 2の画像 2
    • Use a T10 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
  2. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 2、 3の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 2、 3の画像 2 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 2、 3の画像 3
    • Using precision tweezers, remove the screw tab located on the opposite side of the box.
    • Use a T10 Torx screwdriver to remove the 13mm screw revealed underneath the tab.
  3. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 3、 3の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 3、 3の画像 2 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 3、 3の画像 3
    • Orient the case so that the front of the Xbox (the side with the power button) is facing you.
    • Remove the top of the case by sliding the case towards you.
  4. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 4、 3の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 4、 3の画像 2 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 4、 3の画像 3
    • Using a T9 or T8 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
    • Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
  5. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 5、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 5、 2の画像 2
    • Remove the unscrewed panel from the side of the device by pulling it toward you.
    • Be mindful of the connector, as it is fragile.
  6. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 6、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 6、 2の画像 2
    • Above the black slot is a white switch, fold it over with your fingernail, and fold it over to the front. Then the cable can be easily removed without any problems.
    • Do not force the connector out, as it is fragile. Wiggling may be necessary.
  7. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 7、 3の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 7、 3の画像 2 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 7、 3の画像 3
    • On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
    • Remove both of these 7mm screws with a Torx T8 screwdriver.
    • Lift the detached plate off to the side.
    • The plate is still connected to the device.
  8. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 8、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 8、 2の画像 2
    • Use a Torx T10 screwdriver to remove the six 47mm long screws, which attach to the bottom side of the outer case.
  9. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 9、 3の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 9、 3の画像 2 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 9、 3の画像 3
    • Turn the Xbox over, so that the bottom of the case is on top.
    • Lift the bottom of the case off of the Xbox by pulling it up and toward you.
  10. Xbox One X Project Scorpio Edition HDD to SSD Replacement, BD-ROM Drive: 手順 10、 1の画像 1
    • Flip over the device again, so that the top is facing upwards.
    • Remove the 4 smaller 11mm screws in the lower left corner of the metal casing using a Torx T10 screwdriver.
  11. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 11、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 11、 2の画像 2
    • Flip over the device again, so that the bottom is facing upwards.
    • Using a Torx T10 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
    • The left screw is 11mm and the right screw is 7.5 mm.
  12. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 12、 3の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 12、 3の画像 2 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 12、 3の画像 3
    • Remove the metal casing by pulling it upward, revealing the interior components of the device.
  13. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 13、 3の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 13、 3の画像 2 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 13、 3の画像 3
    • Lift and rotate the BD drive to reveal the wires that connect it to the motherboard.
  14. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 14、 3の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 14、 3の画像 2 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 14、 3の画像 3
    • Using your fingers, gently unplug the two sets of wires connecting the drive to the motherboard.
    • Alternatively, you can disconnect the wires from the drive-side sockets. This is much easier if you have not removed the power supply.
    • The BD drive should now be completely detached from the rest of the device, and it can be set aside.
  15. Xbox One X Project Scorpio Edition HDD to SSD Replacement, Unplug the bundled cable connector: 手順 15、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement, Unplug the bundled cable connector: 手順 15、 2の画像 2
    • Unplug the bundled cable connector connecting the hard drive to the motherboard by pulling directly upward.
  16. Xbox One X Project Scorpio Edition HDD to SSD Replacement, Unplug the SATA cable: 手順 16、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement, Unplug the SATA cable: 手順 16、 2の画像 2
    • Unplug the SATA cable connecting the hard drive to the motherboard by pulling directly upward.
  17. Xbox One X Project Scorpio Edition HDD to SSD Replacement, Remove the hard drive: 手順 17、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement, Remove the hard drive: 手順 17、 2の画像 2
    • Lift the hard drive assembly up out of the upper metal case.
    • When moving the hard drive, hold it by the sides to prevent damage.
  18. Xbox One X Project Scorpio Edition HDD to SSD Replacement, Remove the mounting bracket: 手順 18、 1の画像 1
    • Flip the hard drive over so that the plastic mounting bracket is facing upward.
    • Use a T10 Torx screwdriver to remove the four 8.6 mm screws attaching the hard drive to the mounting bracket.
  19. Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 19、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement: 手順 19、 2の画像 2
    • Lift the mounting bracket off the hard drive.
  20. Xbox One X Project Scorpio Edition HDD to SSD Replacement, Unplug the hard drive connector: 手順 20、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement, Unplug the hard drive connector: 手順 20、 2の画像 2
    • Unplug the hard drive connector from the hard drive by pulling parallel to the length of the drive.
  21. Xbox One X Project Scorpio Edition HDD to SSD Replacement, New Drive: 手順 21、 2の画像 1 Xbox One X Project Scorpio Edition HDD to SSD Replacement, New Drive: 手順 21、 2の画像 2
    • Plug in the new drive.
  22. Xbox One X Project Scorpio Edition HDD to SSD Replacement, Put It All Back Together: 手順 22、 1の画像 1
    • Put the Console back together.
    • Here's a joke for you Fixers. Why do they not allow you to fart in an Apple Store?
    • Because they don't have Windows!
    • Download the Offline Update on a flash drive.
    • Flash drive should be more than 6GB
終わりに
Now It's Game Time! Of course after the updates though.
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
NR26
メンバー登録日: 01/26/22
2,249 ポイント
1ガイドが承認済み
チーム
Kid fixers Kid fixers人のメンバー
Community
149 メンバー
281のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 57
過去 30 日: 257
今までの合計 4,166
