はじめに
This guide covers how to remove the Blu Ray disk drive in the Xbox One X. This is a straightforward process once the outer shell of the Xbox has been removed.
必要な工具と部品
Use a T9 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
Flip over the device again, so that the top is facing upwards.
Remove the 4 smaller 11mm screws in the lower left corner on the metal casing using a Torx T9 screwdriver.
Using your fingers, gently unplug the two sets of wires connecting the drive to the motherboard.
Alternatively, you can disconnect the wires from the drive-side sockets. This is much easier if you have not removed the power supply.
The BD drive should now be completely detached from the rest of the device, and it can be set aside.
4 の人々がこのガイドを完成させました。
5 件のコメント
ok it says no other parts required besides the tweezers and the t9 screw driver, but it doesn't mention what model of BD-ROM is suitable to replace it with.
Please FIX Number 8 THIS IS NOT RIGHT!
Unfortunately the manual is not correct here. Above the black slot is a white switch / pen, fold it over with your fingernail, so fold it over to the front. Then the cable can be easily removed without any problems and tweezers. GERMAN: Hier ist die Anleitung leider nicht korrekt. Oberhalb des schwarzen Steckplatzes befindet sich ein weißer Schalter/Stift, diesen mit dem Fingernagel umklappen, also praktisch zu der Vorderseite umklappen. Danach lässt sich das Kabel ohne Probleme und Pinzette einfach abziehen.
What is the model of the BD ROM drive for the xBox 1 X?
Followed this guide and https://www.youtube.com/watch?v=wO-QanKR... and upgraded my Xbox One X Project Scorpio edition to 2TB SSD. Thanks and keep up the good work
