メインコンテンツにスキップ
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
必要な工具と部品
  1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: 手順 1、 2の画像 1 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: 手順 1、 2の画像 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 手順 2、 2の画像 1 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 手順 2、 2の画像 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Only use a pry tool! The vibration motor wires are exposed and directly accessible from the side when opening. I attempted to open it with a small knife, expecting to be able to gently pry the clips open, accidentally sliced through my right motor’s wires.
    Sawyer Coe - 返信
    Not a sharp of course.
    kajussls121 -
    If you have some Guitar picks laying around they work GREAT!
    Mike Beane - 返信
  3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 手順 3、 1の画像 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Torx-8 security bits work as well.
    jahiamir - 返信
    Torx 8 or 9 wasn’t working. I used 2.0 minus screwdriver
    richjlee - 返信
    The 2.0 minus worked for me as well.
    metric - 返信
    When sliding in the plastic cover during reassembly be sure it lines up with the battery compartment contacts. It can be really easy to not see it and bend the contacts. If you still encounter force during this step, depressing the triggers out of the way worked for me.
    Drew - 返信
    Since mine is out of warranty I just broke out the security nib with a 2.0 standard bit. Then used a T8 torx.
    Tim LaCrosse - 返信
  4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 手順 4、 3の画像 1 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 手順 4、 3の画像 2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 手順 4、 3の画像 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 手順 5、 2の画像 1 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 手順 5、 2の画像 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 手順 6、 1の画像 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    Reassembly: When placing the back cover on: notice that the battery terminals need to slide inside the cover first. Then compress the triggers slightly, Then the cover will be aligned correctly. Then add the front cover and add screws so it doesn’t come undone.
    hunteil - 返信
    It isn't necessary to take off the back cover
    Otto Hahn - 返信
終わりに
49 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Weston Gilmore
メンバー登録日: 09/25/17
1,789 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017人のメンバー
CPSU-FORTE-F17S18G3
4 メンバー
32のガイドは作成済み
4 件のコメント
i used a t8 and it worked
Rudy Bp - 返信
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - 返信
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - 返信
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 62
過去 30 日: 283
今までの合計 24,382
