はじめに
The audio port on your Xbox Controller could have connection issues with audio devices or not provide any sound at all. If this is occurring it might be necessary to replace the 3.5 mm audio port. This guide will teach you how to access and remove the 3.5 mm audio port on your Xbox One Wireless Controller Model 1708.
パーツ
パーツは指定されていません。
Slide the battery cover toward the top of the controller to remove it.
Lift up the batteries or the battery pack from the battery compartment.
Tape the Rumbler/shock motors in place.
This will prevent the motors from falling out.
Turn the device over and remove the directional pad by gently pulling it away from the controller.
Turn the device over and remove the two 7.0mm torx-6 screws in the bottom left and right corners.
Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
22 の人々がこのガイドを完成させました。
6 件のコメント
Where do I get a replacement audio port?
Hey Cory,
Sorry, didn’t realize that the part wouldn’t get listed for the guide. I looked around a bit and I would say that it seems the best place to pick these up is ebay.
I found one on there from a reputable seller for $3:
https://www.ebay.com/itm/Repair-Part-3-5...
The seller seems to sell a good amount of these.
Hope that helps!
I removed the 3.5mm jack, cleaned the contacts with a fibre glass contact cleaning brush, and then cleaned both the audio connector and the gold plated PCB pads with IPA, reassembled, and everything worked perfectly. Thanks for the guide, it’s boarder line perfect ;-)
Paul Hough - 返信
