メインコンテンツにスキップ
Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement
必要な工具と部品
  1. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement, Bumper: 手順 1、 1の画像 1
    • Remove the battery cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 2、 3の画像 1 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 2、 3の画像 2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 2、 3の画像 3
    • Grip the controller firmly to remove the side handle cover.
    • Use a flathead screwdriver or a spudger to wedge between the seams of the front to the side handle of the controller.
    • Move the flathead screwdriver all the way around the side plates seam and push the plate forward.
  3. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 3、 2の画像 1 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 3、 2の画像 2
    • Use a screwdriver and punch a hole directly in the center label. There you will find a hidden screw.
    • Remove the five 10mm screws located on the back of the controller using a T8 screwdriver.
  4. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 4、 2の画像 1 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 4、 2の画像 2
    • Remove the backplate.
  5. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 5、 2の画像 1 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 5、 2の画像 2
    • Remove the faceplate.
  6. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 6、 3の画像 1 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 6、 3の画像 2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 6、 3の画像 3
    • Remove the cover piece surrounding the Xbox button off of its pegs.
    • Firmly hold controller and push cover piece up from the pegs.
    • Press the Xbox button down to assist in the unclipping of the piece.
  7. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 7、 2の画像 1 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 7、 2の画像 2
    • Remove the broken bumper by unclipping it from its pegs.
    • Hold the controller firmly and push the bumper piece up from its pegs to unclip.
  8. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 8、 3の画像 1 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 8、 3の画像 2 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 手順 8、 3の画像 3
    • Align the replacement bumper onto the pegs, push gently and click into place.
終わりに
18 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cristyne Ramirez
メンバー登録日: 01/24/18
541 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018人のメンバー
USFSM-STEWART-S18S1G1
15 メンバー
25のガイドは作成済み
2 件のコメント
On my controller the screws were T8 security type, so you'll need bits with a hole in the middle
Sean H - 返信
Is there a way to do this without removing all of the front and grip.
Alan Marantos - 返信
コメントを追加
統計データ:
過去 24時間: 28
過去 7 日: 187
過去 30 日: 949
今までの合計 40,878
