はじめに
This guide will teach you how to replace the D-pad.
ツール
パーツ
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the T8 Security Torx Screwdriver.
41 の人々がこのガイドを完成させました。
6 件のコメント
Can you show me how to replace xbox one controller 3.5mm stereo jack dpad
This model of the xbox one controller does not feature a 3.5mm headphone jack. Please look at the guides for later models of the xbox one controller.
Brandon -
it's exactly the same like shown above :)
