メインコンテンツにスキップ
はじめに
This guide will show you how to remove the motherboards in order to access the buttons and triggers.
  1. Remove the battery pack cover.
    • Remove the battery pack cover.
    • Remove batteries.
  2. We recommend using a nylon spudger for this step. A metal spudger is shown. Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. There is a hidden screw located in the middle of the controller behind the label. Use a screwdriver and punch a hole directly in the center of the label.
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the T8 Security Torx Screwdriver.
  4. Remove the backplate.
    • Remove the backplate.
  5. Remove the faceplate.
    • Remove the faceplate.
  6. You may let the rumble motors hang freely out of their sockets. De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
  7. Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
  8. Firmly grip sides of motherboard near the middle.
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
  9. Remove the yellow tape holding the wires in place on the front of the controller.
    • Remove the yellow tape holding the wires in place on the front of the controller.
  10. Unscrew the two 7mm T6 Hex screws located on underside the triggers. Unscrew the two 7mm T6 Hex screws located on underside the triggers. Unscrew the two 7mm T6 Hex screws located on underside the triggers.
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
  11. Remove the trigger covers.
    • Remove the trigger covers.
  12. Desolder the wires from the motherboard.
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
  13. Remove the six T6 Torx screws located on the bottom motherboard. Remove the six T6 Torx screws located on the bottom motherboard.
    • Remove the six T6 Torx screws located on the bottom motherboard.
  14. Remove the bumpers by prying them off of the pegs that secure them, using a spudger.  They are located on the front and back of the controller. A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
    • Remove the bumpers by prying them off of the pegs that secure them, using a spudger. They are located on the front and back of the controller.
    • A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
  15. Lift the piece surrounding the Home button off of its pegs. Pry it off of the other side, using a spudger on the pins.
    • Lift the piece surrounding the Home button off of its pegs.
    • Pry it off of the other side, using a spudger on the pins.
    • Removing this piece may require a lot of force.
  16. Remove the bottom motherboard.
    • Remove the bottom motherboard.
終わりに
26 の人々がこのガイドを完成させました。
Liam Gow
メンバー登録日: 2015年01月22日
4,968 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 20-15, Maness Winter 2015 Cal Poly, Team 20-15, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S20G15
5 メンバー
48のガイドは作成済み
10 件のコメント
Is de-soldering optional?
John Gonzalez - 返信
Considering the placement of wires attached by solder on both sides of the top board, it would be quite difficult to reach anything beneath it otherwise. I suppose it depends on what you're trying to achieve.
In any case, you might as well try to move it without desoldering if desoldering is going to be an issue. Make sure not to pull hard, though.
Liam Gow -
I have a question... Will the motherboard you can get at the store here work it the newer controllers with built in headphone jack?
ETHREAL1 - 返信
I would expect not, I'm afraid. The motherboards will probably have different circuitry, even if the shapes are the same, which they may not be.
Liam Gow -
The position/mounting of the LB and RB buttons on the motherboard piece between the day-one/sans-jack and the newer 3.5mm jack (non-Slim) boards are completely different.
The older revision motherboard has the mountings inverted (pointing downwards to the south end-headset attachment port- of the controller) compared to the newer ones.
The newer ones have the circuit with the bumper buttons mounted pointing to the north end toward the bumpers on the top of the controller.
icho - 返信
コメントを追加
統計データを表示:
過去 24時間: 9
過去 7 日: 88
過去 30 日: 423
今までの合計 49,124
