メインコンテンツにスキップ
Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment
必要な工具と部品
  1. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): 手順 1、 3の画像 1 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): 手順 1、 3の画像 2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): 手順 1、 3の画像 3
    この手順で使用する道具:
    Essential Electronics Toolkit
    $29.95
    購入する
    • Remove the batteries from your controller (if installed). If you do not have a TR8 screwdriver, the bit is in the Essential Electronics Toolkit.
    • Remove the screw under the battery cover label. To do this, puncture the label where it is marked. It is located roughly in the center of the battery bay on the controller.
    • Remove the side trim from the controller, along with the 4 TR8 screws. Set the trim and screws aside somewhere safe.
  2. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): 手順 2、 3の画像 1 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): 手順 2、 3の画像 2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): 手順 2、 3の画像 3
    この手順で使用する道具:
    iFixit Opening Tool
    購入する
    • Author's note: I have no intention of retaking these photos as I do not have my 1697 anymore (and avoid them when possible). I can do this with one hand, but using a pry tool in the area marked in orange makes this easier.
    • With the screws removed from the back, flip the controller to the front. Remove the front plastic cover.
    • With the front plastic cover removed, remove the back shell. A plastic pry tool can be used if it is easier.
    • Remove the shell once the battery tabs are released.
  3. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): 手順 3、 3の画像 1 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): 手順 3、 3の画像 2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): 手順 3、 3の画像 3
    この手順で使用する道具:
    iFixit Opening Tool
    購入する
    • Remove the power button cover from the controller. If the LB/RB assembly is separate, remove this next. A plastic pry tool can also be used.
    • Remove the wireless sync button. Place this on a bright surface to avoid misplacement.
  4. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: 手順 4、 3の画像 1 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: 手順 4、 3の画像 2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: 手順 4、 3の画像 3
    この手順で使用する道具:
    Precision Utility Knife
    購入する
    • Repair one trigger at a time!
    • Before cutting the heatshrink, make TWO alignment marks (non-crossing).
    • After making alignment marks, cut the heatshrink off using a utility knife.
    • Using the old heatshrink as a reference, cut two new pieces.
  5. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 手順 5、 3の画像 1 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 手順 5、 3の画像 2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 手順 5、 3の画像 3
    • Incorrect magnet alignment will result in LT/RT activation without human input.
    • After cutting the heatshrink tubing, do a test alignment before applying glue.
    • These controllers use double sided tape from the factory. Note the dimple side and clean the magnet and frame. Goo Gone can be used on difficult residue.
    • Once the parts are reasonably clean, do a test alignment and apply tape for final installation.
  6. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: 手順 6、 2の画像 1 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: 手順 6、 2の画像 2
    • A controller frame may be required if done incorrectly. Verify the alignment before adding glue!
    • After verifying the alignment is correct, apply glue to the controller. It is best to let it cure for 24 hours if possible.
  7. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Install new heatshrink tubing: 手順 7、 1の画像 1
    この手順で使用する道具:
    Heat Shrink Tubing Assortment
    $7.99
    購入する
    • Soft flame lighters may melt the plastic. Blue flame lighters are generally safer for this!
    • Once the glue cures, add new heatshrink tubing.
ゴール
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
88,987 ポイント
50のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,466のガイドは作成済み
4 件のコメント
Do you know any specs on the magnet itself? I have a controller that is missing a magnet, and can’t find any information on the strength of the magnet. Without that there’s no way to get a replacement.
Eric Harper - 返信
same here cant find it any were
conman3609 -
Ma gachette RT reste enfoncé c quoi le problème.
Merci d'avance
Chawki Bourokba - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 41
過去 30 日: 164
今までの合計 21,848
