メインコンテンツにスキップ
Xbox One Stereo Headset Circuit Board Replacement
必要な工具と部品
  1. Xbox One Stereo Headset Circuit Board Replacement, Adapter Circuit Board: 手順 1、 2の画像 1 Xbox One Stereo Headset Circuit Board Replacement, Adapter Circuit Board: 手順 1、 2の画像 2
    • Insert the flat edge of a metal spudger in the seam between the adapter body and the plastic casing. Move the spudger into one of the corners.
    • Push down on the spudger to separate the casing from the adapter until you hear a click and the casing stays open on that side.
    • Do the same to the other side until the casing comes off.
    • When reassembling, first align the headphone jack in the back of the adapter body with the hole in the casing, then align the tabs on the floor of the casing with the holes in the bottom of the adapter body.
  2. Xbox One Stereo Headset Circuit Board Replacement: 手順 2、 1の画像 1
    • Remove three 5.0 mm T5 Security Torx screws along the edges of the controller housing.
    • Remove two 8.0 mm T5 Security Torx screws near the top-center of the adapter.
  3. Xbox One Stereo Headset Circuit Board Replacement: 手順 3、 1の画像 1
    • With your fingers, carefully lift the adapter housing from the button panel.
    • Be careful not to yank the wires connecting the two halves of the circuit board.
  4. Xbox One Stereo Headset Circuit Board Replacement: 手順 4、 1の画像 1
    • Pull back on the controller USB connector with your interview to separate the main adapter circuit board from the rubber mold in the button panel.
  5. Xbox One Stereo Headset Circuit Board Replacement: 手順 5、 1の画像 1
    • Remove the two 5.5 mm Phillips #00 screws connecting the smaller circuit board to the adapter housing. The smaller circuit board should come right off.
    • One of the screws is located beneath the connecting wires, so you may have to move the main circuit board around until you can see the screw.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Justin Rosescu
メンバー登録日: 01/30/15
500 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 17-37, Amido Winter 2015 Cal Poly, Team 17-37, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S17G37
4 メンバー
5のガイドは作成済み
2 件のコメント
Where do i get the circuit board to buy ?
Ramesh Sirdar - 返信
Thank you, I opened the adapter in minutes, which is all I wanted to do.
Laurschanny - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 17
今までの合計 7,341
