はじめに
Access all hardware inside the Xbox One S All Digital Edition (Model 1681) metal casing after completing this step.
This step shows how to carefully separate the top metal casing from the bottom. If there are noises from the fan, the metal casing could be the problem, prohibiting fan movement. Disconnect all cables prior to disassembly.
必要な工具と部品
Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
Repeat on different points of the plastic enclosure until the bottom cover is removed.
Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
2 の人々がこのガイドを完成させました。
