メインコンテンツにスキップ
Xbox One Kinect Outer Shell Replacement
必要な工具と部品
  1. Xbox One Kinect Outer Shell Replacement, Outer Shell: 手順 1、 1の画像 1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
  2. Xbox One Kinect Outer Shell Replacement: 手順 2、 3の画像 1 Xbox One Kinect Outer Shell Replacement: 手順 2、 3の画像 2 Xbox One Kinect Outer Shell Replacement: 手順 2、 3の画像 3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
  3. Xbox One Kinect Outer Shell Replacement: 手順 3、 3の画像 1 Xbox One Kinect Outer Shell Replacement: 手順 3、 3の画像 2 Xbox One Kinect Outer Shell Replacement: 手順 3、 3の画像 3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
終わりに
作成者
4人の作成者と共同で作成されました。
Charles Schoonover
メンバー登録日: 09/22/14
215 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014人のメンバー
USFT-HICKMAN-F14S1G3
4 メンバー
7のガイドは作成済み
コメント 1 件
Again, another great guide, guys. Also, this is a solid prerequisite. I noticed when reviewing this one that you did a good job of indicating which tools to use and when. Your markup is clear and concise, and your writing is not overly technical and complicated. Your photos and action steps are also very clear. You did a great job this semester!
P.S. -- I'm not sure if we're actually supposed to post our reviews as comments here. You may not want them on your guides! If I'm mistaken here, don't hesitate to remove them. I'm submitting through Canvas as well.
Noah Hickerson - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 2,220
