メインコンテンツにスキップ
Xbox One Kinect Infrared Camera Replacement
必要な工具と部品
  1. Xbox One Kinect Infrared Camera Replacement, Outer Shell: 手順 1、 1の画像 1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
  2. Xbox One Kinect Infrared Camera Replacement: 手順 2、 3の画像 1 Xbox One Kinect Infrared Camera Replacement: 手順 2、 3の画像 2 Xbox One Kinect Infrared Camera Replacement: 手順 2、 3の画像 3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
  3. Xbox One Kinect Infrared Camera Replacement: 手順 3、 3の画像 1 Xbox One Kinect Infrared Camera Replacement: 手順 3、 3の画像 2 Xbox One Kinect Infrared Camera Replacement: 手順 3、 3の画像 3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
  4. Xbox One Kinect Infrared Camera Replacement, Heat Sink Assembly: 手順 4、 2の画像 1 Xbox One Kinect Infrared Camera Replacement, Heat Sink Assembly: 手順 4、 2の画像 2
    • Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
    • Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
  5. Xbox One Kinect Infrared Camera Replacement: 手順 5、 3の画像 1 Xbox One Kinect Infrared Camera Replacement: 手順 5、 3の画像 2 Xbox One Kinect Infrared Camera Replacement: 手順 5、 3の画像 3
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
  6. Xbox One Kinect Infrared Camera Replacement: 手順 6、 3の画像 1 Xbox One Kinect Infrared Camera Replacement: 手順 6、 3の画像 2 Xbox One Kinect Infrared Camera Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Detach the ribbon cable leading to the microphone with the tweezers.
    • Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly.
    • Remove the stand.
  7. Xbox One Kinect Infrared Camera Replacement: 手順 7、 3の画像 1 Xbox One Kinect Infrared Camera Replacement: 手順 7、 3の画像 2 Xbox One Kinect Infrared Camera Replacement: 手順 7、 3の画像 3
    • Remove the eight 3.0x7.6 mm T9 screws from the motherboard.
    • Peel away the plastic film from the motherboard using the spudger.
    • Detach the ribbon cable leading to the color camera using the spudger.
  8. Xbox One Kinect Infrared Camera Replacement: 手順 8、 3の画像 1 Xbox One Kinect Infrared Camera Replacement: 手順 8、 3の画像 2 Xbox One Kinect Infrared Camera Replacement: 手順 8、 3の画像 3
    • Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
  9. Xbox One Kinect Infrared Camera Replacement, Infrared Camera: 手順 9、 3の画像 1 Xbox One Kinect Infrared Camera Replacement, Infrared Camera: 手順 9、 3の画像 2 Xbox One Kinect Infrared Camera Replacement, Infrared Camera: 手順 9、 3の画像 3
    • First step is to make sure that the inner compartment containg the camera is separated from the outer casing.
  10. Xbox One Kinect Infrared Camera Replacement: 手順 10、 2の画像 1 Xbox One Kinect Infrared Camera Replacement: 手順 10、 2の画像 2
    • Once the area where the camera is found is uncovered, use the T5 Torx Screwdriver to remove the four 1.9x10.2 mm screws.
  11. Xbox One Kinect Infrared Camera Replacement: 手順 11、 2の画像 1 Xbox One Kinect Infrared Camera Replacement: 手順 11、 2の画像 2
    • Using the spudger, detach the camera from the base.
終わりに
作成者
3人の作成者と共同で作成されました。
Laura Gonzalez
メンバー登録日: 09/22/14
106 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014人のメンバー
USFT-HICKMAN-F14S1G3
4 メンバー
7のガイドは作成済み
コメント 1 件
I have the new Infrared Camera ,1080p HD wide-angle camera,motherboard, IR projectors board.If you need please contact me.
mouyi chen - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 19
今までの合計 1,867
