メインコンテンツにスキップ
Xbox One Hard Drive Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Xbox One Hard Drive Replacement, Side Vent: 手順 1、 3の画像 1 Xbox One Hard Drive Replacement, Side Vent: 手順 1、 3の画像 2 Xbox One Hard Drive Replacement, Side Vent: 手順 1、 3の画像 3
    • With a plastic opening tool, pry the side vent from the console.
    • Start from the back edge and work towards the front of the console.
  2. Xbox One Hard Drive Replacement, Wi-Fi Board: 手順 2、 2の画像 1 Xbox One Hard Drive Replacement, Wi-Fi Board: 手順 2、 2の画像 2
    • Slide the black angled tab behind the silver button toward the back of the console and set it aside.
  3. Xbox One Hard Drive Replacement: 手順 3、 3の画像 1 Xbox One Hard Drive Replacement: 手順 3、 3の画像 2 Xbox One Hard Drive Replacement: 手順 3、 3の画像 3
    • Rotate the Xbox and remove the warranty sticker from the back. Removing this seal and opening the case of the Xbox voids your warranty with Microsoft.
    • Use a plastic opening tool on the back to pry the top of the case from the bottom. Use an up and out motion to dislodge the clips. There are multiple clips to release on the back and two on the sides.
    • This step may take up more time than the others, keep prying with the plastic opening tool and when you release one clip, wedge something underneath it so it doesn't close again.
  4. Xbox One Hard Drive Replacement: 手順 4、 2の画像 1 Xbox One Hard Drive Replacement: 手順 4、 2の画像 2
    • Carefully lift the top of the case, note that there is a wire connecting the front panel to the motherboard. Take care not to break this.
    • Using a spudger, release the ribbon wire from the front panel.
    • The top case is now free, set it aside.
  5. Xbox One Hard Drive Replacement: 手順 5、 3の画像 1 Xbox One Hard Drive Replacement: 手順 5、 3の画像 2 Xbox One Hard Drive Replacement: 手順 5、 3の画像 3
    • Remove the speaker by squeezing the the tab on the black plastic mounting piece and lifting it up.
    • Carefully unplug the connector from the green front panel board.
    • The speaker is now free, set it aside.
  6. Xbox One Hard Drive Replacement: 手順 6、 2の画像 1 Xbox One Hard Drive Replacement: 手順 6、 2の画像 2
    • Unscrew the two 8.2mm T-9 screws securing the Wi-Fi board to the chassis.
    • Using the spudger, gently lift the antenna connector from the Wi-Fi board.
  7. Xbox One Hard Drive Replacement: 手順 7、 2の画像 1 Xbox One Hard Drive Replacement: 手順 7、 2の画像 2
    • Using a spudger and a motion similar to the previous step, gently lift the antenna connector from the green board on the front.
    • Carefully pull out the clips securing the antenna wire to the chassis, releasing the wire.
  8. Xbox One Hard Drive Replacement: 手順 8、 1の画像 1
    • Carefully pull the Wi-Fi board straight up to release it from the chassis. The Wi-Fi board is now free.
  9. Xbox One Hard Drive Replacement, Optical/Disc Drive: 手順 9、 2の画像 1 Xbox One Hard Drive Replacement, Optical/Disc Drive: 手順 9、 2の画像 2
    • Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
  10. Xbox One Hard Drive Replacement: 手順 10、 3の画像 1 Xbox One Hard Drive Replacement: 手順 10、 3の画像 2 Xbox One Hard Drive Replacement: 手順 10、 3の画像 3
    • Lift the chassis top, being careful not to break the wire connecting the chassis top to the motherboard.
    • Unplug the connector labeled 3 on the motherboard by gently pulling up.
    • The chassis top is now free, set it aside.
  11. Xbox One Hard Drive Replacement: 手順 11、 3の画像 1 Xbox One Hard Drive Replacement: 手順 11、 3の画像 2 Xbox One Hard Drive Replacement: 手順 11、 3の画像 3
    • Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
    • Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • The optical drive is now free, lift it from the chassis and set it aside.
  12. Xbox One Hard Drive Replacement, Hard Drive: 手順 12、 2の画像 1 Xbox One Hard Drive Replacement, Hard Drive: 手順 12、 2の画像 2
    • Unplug the red wire connecting the hard drive to the motherboard from its connector on the motherboard.
    • Unplug the multi-colored wire connecting the hard drive to the motherboard from its connector on the motherboard.
    • The hard drive is now free, remove it from the chassis by lifting straight up. Set it aside.
終わりに
12 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Gwendolyn Church
メンバー登録日: 01/27/14
1,500 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 6-22, Maness Winter 2014 Cal Poly, Team 6-22, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S6G22
4 メンバー
11のガイドは作成済み
コメント 1 件
Do you possibly have a list of the relevant files that should be on the new hard drive? I put mine back it, did the whole plug in ethernet and let it sit, nothing. tried flashing update, nothing. factory reset file, E200 so i pulled it back apart and am looking at the file set up on my desktop trying to determine if there are any missing files. any help is appreciated.
Jeremy Murphy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 6,701
