必要な工具と部品
もう少しです!
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
終わりに
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
I found that it is not necessary to take out the hard drive in order to remove the front panel module. If you can lift the whole metal enclosure a little to get to the right most torx screw, then you do not need to move the hard drive.
Taiji Saotome - 返信
Thanks for letting us know about when the open day is going to be. Will make sure get my work completed by rushmyessay before the day so I can attend it in peace.
shuaib ahmd - 返信
