メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのXbox One Elite Wireless Controller Series 2を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Xbox One Elite Wireless Controller Series 2 Teardown, Gather Tools: 手順 1、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Gather Tools: 手順 1、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Gather Tools: 手順 1、 3の画像 3
    • Gather your tools!!!
  2. Xbox One Elite Wireless Controller Series 2 Teardown, Remove Faceplate: 手順 2、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Remove Faceplate: 手順 2、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Remove Faceplate: 手順 2、 3の画像 3
    • Grab that trusty plastic pry tool and start popping off the faceplate. Begin at the top near the bumpers and work down each grip—like peeling a banana, but way cooler.. You may like to remove the magnetic thumb sticks for more clearance.
    • The clips are quite sturdy and you shouldn't be afraid to be firm with removing the faceplate to dislodge the clips. Give it a good, firm push to dislodge them. There are four clips down each grip and there is also dampening tape which isnt an IP requirement and wont need replacing.
  3. Xbox One Elite Wireless Controller Series 2 Teardown, Removing Joysticks: 手順 3、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Removing Joysticks: 手順 3、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Removing Joysticks: 手順 3、 3の画像 3
    • The joysticks are screwed onto the potentiometers and are very tight, probably more secure than your grip after a long gaming session.
    • Don’t get tricked by that tempting screw in plain sight—that’s a tensioning screw. You will need to turn the joystick counter clockwise to remove using either the thumbstick or a pair of pliers.
    • Note: If you are reusing the joysticks be careful not to let the pliers slip and damage the thumbstick mounting grooves.
  4. Xbox One Elite Wireless Controller Series 2 Teardown, Separating the Back: 手順 4、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Separating the Back: 手順 4、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Separating the Back: 手順 4、 3の画像 3
    • Remove the 6 x T-8 Security Torx Screws holding the front and back together. The Red circled screw will have a white sticker over it, if the sticker’s missing, someone else has already peeked inside—maybe looking for buried treasure.
    • Good news! All the screws are the same length and you do not need to remember positions. Once the screws have been removed you will be able to lever near the bottom of the grips to remove the back of the controller (red arrow)
  5. Xbox One Elite Wireless Controller Series 2 Teardown, Removing the Bumpers: 手順 5、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Removing the Bumpers: 手順 5、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Removing the Bumpers: 手順 5、 3の画像 3
    • There are two tabs holding the centre bar between bumpers in place. Using a small blade pop these upwards to remove space up the centre bar.
    • There are also two tabs on either end of the RB and LB bumpers facing outwards marked with a yellow circle. Remove one end by lifting the slotted tab off the pin and the other end should be free to slide off. Boom—you’re officially breaking down barriers, one bumper at a time.
  6. Xbox One Elite Wireless Controller Series 2 Teardown, Remove Connecting Cables: 手順 6、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Remove Connecting Cables: 手順 6、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Remove Connecting Cables: 手順 6、 3の画像 3
    • Time to play “peek-a-boo” with the motherboard! Peel back tape covering the connection on the motherboard. While holding the tape back use a small plastic blade too dislodge the connections, these pop upwards like a shirt clip button.
  7. Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Motherboard: 手順 7、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Motherboard: 手順 7、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Motherboard: 手順 7、 3の画像 3
    • Now, for the serious stuff—There are four solder points on the left and right that can be de-soldered depending on what is required during a repair. The temperature required to remove is approx 450 degrees C.
    • If you arent removing the solder be careful while removing the motherboard in this step.
    • Remove the 2 T6 Torx screws (yellow circle) and gently slide the motherboard up along the two dowel pins (red circle). The motherboard (green) can now be repositioned away from the daughterboard(blue).
    • The black and grey wires are looped through the plastic tabs on either end as well as around the front of the plastic panel (yellow circle), removing them from here can allow more free room without de-soldering.
    • The headphone jack can now also be removed (red square)
  8. Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Triggers: 手順 8、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Triggers: 手順 8、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Triggers: 手順 8、 3の画像 3
    • Remove the T-6 Torx screws from each trigger button.
    • Almost there! There’s a tiny latch on each trigger that you can lever outwards, allowing you to pop the trigger and motor assembly free from the case. And then the motors can be separated from the trigger case
  9. Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Daughterboard: 手順 9、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Daughterboard: 手順 9、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Remove the Daughterboard: 手順 9、 3の画像 3
    • Remove the 4 T-6 Torx screws (yellow circles) holding down the daughterboard.
    • Slide the daughterboard up along the dowel pin in the bottom left corner (red circle).
    • The remaining buttons will also become dislodged during this stage. Once removed you will be able to see the unique mounting locations of the buttons which stop incorrect fitment of the buttons during assembly—so no accidental “A” where the “X” should be.
  10. Xbox One Elite Wireless Controller Series 2 Teardown, Celebrate!: 手順 10、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Celebrate!: 手順 10、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Celebrate!: 手順 10、 3の画像 3
    • And that’s it! You’ve made it to the end of your epic teardown. Hopefully this teardown has allowed you to reach the components that require replacement or cleaning!
  11. Xbox One Elite Wireless Controller Series 2 Teardown, Key Components #1: 手順 11、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Key Components #1: 手順 11、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Key Components #1: 手順 11、 3の画像 3
    • Daughterboard
    • Motherboard Side 1
    • Motherboard Side 2
  12. Xbox One Elite Wireless Controller Series 2 Teardown, Key Components #2: 手順 12、 3の画像 1 Xbox One Elite Wireless Controller Series 2 Teardown, Key Components #2: 手順 12、 3の画像 2 Xbox One Elite Wireless Controller Series 2 Teardown, Key Components #2: 手順 12、 3の画像 3
    • Rear Casing - Showing trigger stops and rear paddle hardware
    • Inner Casing - Showing grooves of buttons to stop incorrect fitment
    • MCU - BGA IC Responsible for WiFi and Bluetooth Connectivity (Red Square)
作成者
1人の作成者と共同作成されました。
Danie
メンバー登録日: 11/16/24
205 ポイント
1ガイドが承認済み
コメント 1 件
size of Torx of those triggers?
jun rey mila - 返信
コメントを追加
統計データ:
過去 24時間: 24
過去 7 日: 156
過去 30 日: 510
今までの合計 2,482
